Sign up Log in
How do I move a work log for multiple people that should have logged work under a different project
Russell Shirley February 3, 2016
MattS
February 3, 2016
I bet that a ScriptRunner script could do a bulk move of worklogs. A matter of defining what needs to be done, coding, testing in staging, recoding, run in production at low load. Not trivial but not impossible
Phil,   Just noticed your company tag.. As a FYI.. we use scriptrunner and appreciate the effort your team puts into the ScripRunner project. https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner/server/overview
  Any examples within scriptrunner that will delete worklog from issue A and then add the work log entry to issue B?
Phil,  Sorry I didn't realize that it posted the question..
So here is the problem:
I have 1 month of work by 2 teams that the time was not segregated correctly based on new business rules.   So now I need to fix the time..  As everyone can imagine.   This is not easy to do.
Here is what I found so far:
The bad news is that I have not found a "JIRA" solution for this problem yet however there are some base solutions mentioned by using the Tempo Timesheets plugin smile.
Below is the Feature request for Jira..  Please vote for this if you too have ever had the similar problem to "fix".
https://jira.atlassian.com/browse/JRA-15082
The good news for everyone is that Tempo Time Sheets seems to have some limited functionality.. but alas... not a bulk change..
The topic.
https://answers.atlassian.com/questions/9872768
The open issue
https://tempoplugin.jira.com/browse/TT-1108
I will keep looking for the magic bullet as this problem is pretty ugly to undo.   If anyone has a better solution please let me know.
Other items like everyone should have logged a subtask and time logged on a subtask is a easy retrospective solution .. however how many keystrokes do you place in front of users to log time should be something everyone considers as well smile
Phill Fox
February 3, 2016
What issue are you facing in moving a work log? Perhaps you could provide more context to enable someone to assist you.
