How do I move next-gen issues to an Epic via Rest API?
jiratickets March 26, 2024 edited
I get this error everytime I try to move an issue to an EPIC via a POST Rest API. I wasn't aware about the fact that it was a next-gen issue until I saw this error message. Now that I know, what should I do to eliminate this error?
The error message is provided below:
"errorMessages":["The request contains a next-gen issue. This operation can't add next-gen issues to epics. To add a next-gen issue to an epic, use the Edit issue operation and set the parent property (i.e., '\"parent\":{\"key\":\"PROJ-123\"}' where \"PROJ-123\" has an issue type at level one of the issue type hierarchy). See <a href=\"https://developer.atlassian.com/cloud/jira/platform/rest/v2/\"> developer.atlassian.com </a> for more details."],"errors":{}}
Trudy Claspill
Hello @jiratickets
You need to use a different API endpoint, just as the message says.
Are you unclear about using the Edit operation?
jiratickets March 27, 2024
Hi Trudy,
Yes, I am a bit unclear on the Edit operation. I am using JIRA APIs to create jira issues with attachments. But, now that I need to link it to an existing EPIC, I get this issue.
What do you mean by I need to use a different API endpoint? Could you please explain?
Thank you :)
Trudy Claspill
Trudy Claspill
Hello @jiratickets
Were you able to resolve your issue with the answers I provided, or do you still have questions on this topic?
