How do I query a sub-task for a specific issue type only?
Angela Boston
I would like to query the Issue Type and Sub-Tasks of that specific Issue Type only.  Is there a JQL for this?
Muhammad Ramzan_Atlassian Certified Master_
December 10, 2019
You need a plugin to do this either scriptrunner or  JQL Search Extensions for Jira & reports
I have  JQL Search Extensions for Jira & reports  plugin and using it since long time., its available for both server and cloud
In your case
This query will return all sub tasks of issue type epic , you can change the issue type as per your need.
issue in subTaskOf("issuetype=epic")
Angela Boston
Would I be able to pull in the Issue Type and the Sub Tasks of that Issue Type?
Example, I have the Issue Type of Creative Request.  I want to pull the Creative Request tickets and the Sub-Tasks of those Creative Request tickets.
Daniel Turczanski - JQL Search Extensions
@Angela Boston  why not just use:
issuetype="Creative Request" and issue in subTaskOf("issuetype='Creative Request'")
Angela Boston
I tried that and get this error message
Unable to find JQL function 'subTaskOf(issuetype='Creative Request')'.
December 30, 2019
@Angela Boston  you need to install  JQL Search Extensions for Jira & reports plugin
Angela Boston
Can this be accomplished with ScriptRunner?
Kristian Walker (Adaptavist)
Hi Angela,
Thank you for your question.
I can confirm that the Enhanced Search for Jira Cloud plugin contains the subtasksOf() search function that you can use to query subtasks related to an issue.
The documentation page located here explains how this works in more detail and may be useful to help you to achieve your requirement.
If this response has answered your question can you please mark it as accepted so that other users can see it is correct when searching for similar answers.
Kristian
Libu B
not sure if I understood your question correctly. Are you looking for something like this
=project = ABC AND issuetype in (Bug, Story, Task, Sub-task)
Angela Boston
I'm looking to return the Issue Type and Sub-Tasks of that Issue Type only.
Example, the Issue Type is Creative Request.  I want to pull all Creative Requests and the Sub-Tasks of only the Creative Requests issue types.
Like # people like this
