Hello @ckopanon ,
Good day! Welcome to Atlassian community :)
Currently, its not possible to hide Priority from cards. We have a feature request for the same:
JSWCLOUD-9695: Ability to remove the priority icon from Agile boards
As a workaround, you can remove the Priority field using the project's field configuration.
Thank you!
@Shalini Pradhan it doesn't work so - I have removed priority field from field configurations but priority is still showing on the card.
In order to remove the priority field from the card you have to remove it from the field configuration that the project is using. Note that that this would remove the field from the work item layout as well.
@Mikael Sandberg even when I remove Priority field from the field configurations it is still showing priority on the card layout on kanban board.
