×I copied the workflow and now it shows all the copies and I believe they are all active. Need help removing the copies
Those are Workflow Schemes. Navigate to Issues -> Workflow Schemes in the admin tool to find them. From there, you'll be able to tell if they are active or not
Ok i did that and I see that they are inactive. See the picture below. I can just click Delete button....?
Yup. If they are in the inactive section, you're not using them. Safe to delete.
Hi @Chris Szorc
welcome to the community.
Thank you for providing a screenshot, that helps a lot in solving the problem. On the screenshot we can see that you have one workflow which is used in four workflow schemes.
Assuming the copies are not used, you can delete them from the workflow schemes administration page. They should be in the inactive section which can be expanded.
See also the Atlassian docs for more details.
Matthias
