I cloned an issue that was part of a completed sprint. In the past I use to be able to edit the issue and remove the completed sprint. Now it appears JIRA is archiving the completed sprints and I can't edit an issue to remove it from a completed sprint. Is there a way that I'm not finding to remove the issue from a completed sprint?
Community moderators have prevented the ability to post new answers.
Hey @Geoffrey Rodgers,
Can you be more specific? This problem is really giving me a hard time, and I have no idea what you mean by "disassociate the Sprint through the bulk Edit flow."
Please provide step-by-step instructions.
Thank you.
Sure thing, but I want to be clear that this is for clearing *completed* sprint information, for clean-up purposes. * Click Search for Issues in the main menu of JIRA. * Enter criteria that returns the issue or issues for which you want to remove the Sprint information. * Click Tools > Bulk Change (i.e., all ____ issue(s)), even though you may not choose to update all of them. * On Step 1 of 4 of the bulk update flow, choose the issues you want to update, and then click Next. * On Step 2 of 4, select Edit Issues, and then click Next. * On Step 3 of 4, check the box next to the "Sprint" field, and then click Next. * On Step 4 of 4, click Confirm.
This worked for me. Thank you!
Still works as of August, 2015. Good suggestion!
Still works! Just tried it for one cloned issue. Thanks for providing the step-by-step.
THANK YOU! Worked for me!
Thanks so much. Worked a charm :)
Thank you for the instructions - worked like a champ - saved us a bunch of time.
It removed the current sprint and the closed sprint is still there. Not the right solution for me.
Seems that you put the wrong number at step 3
Thanks for that! It helped a lot.
Worked fine for me to clean Sprint in Epics that were messing my velocity reports.
Good step by step instructions. Much appreciated
Still working in June 2020 - thanks, this was very helpful!
Yaay, working like a dream. :-) should have been able to figured this out ...
Bulk Edit to remove a closed sprint from an issue works on Jira Server but there is an open bug on Jira Cloud: https://jira.atlassian.com/browse/JSWCLOUD-17215
The alternate solution for Jira Cloud is to reopen the sprint, move the issue to the backlog, and then reclose the sprint. That approach is described here: https://community.atlassian.com/t5/Jira-Software-questions/How-to-clear-completed-sprint-from-a-ticket/qaq-p/1299651
Thanks Don. That's a time consuming workaround, and if I can't be bothered doing that a million times, is there some nice JQL I can use on my board filter to ignore work that is in a closed sprint?
Because this filter used for the board:
project = MYPROJECT AND sprint = MYSPRINT ORDER BY Rank ASC
Includes tickets in say 2 closed sprints e.g. MYSPRINT01 and MYSPRINT02, and one unrelated open sprint OTHERTEAMSPRINT
No longer works.
The bulk update looks to work, however, historic sprint IDs still remain attached.
This method works on Jira 8.5 at least. Just used it myself a moment ago.
Matthew,
You should be able to disassociate the Sprint through the bulk Edit flow. I just tried it, and it worked.
Geoffrey
Obviously this is a pretty old topic but it is still relevant. I had it today. Also after cloning and issue from the sprint before and this answer my help other.
Situation:
An issue from a finished sprint was cloned and the cloned issue will be inserted into a new sprint. This will may break your old sprint reports and you don't want to have the wrong sprints in the new issue too.
While bulk changing you only have to insert the ID of the current sprint. The sprint from the original ticket will be removed from the clone.
@Dominic Feig is correct. Entering the ID number worked for me. Thanks All!
We're running the cloud version and this DID work about 1 month ago, but has now stopped working.
Worked for me just now in Cloud version by entering a current/future sprint ID. It replaced the old closed sprint. (Leaving it blank did not remove the old closed sprint.)
Yep this is still working for Cloud / on Demand.
After the edit has been made, we no longer see the completed sprints as part of this issue ID, only the future sprint.
This still doesn't work. I cloned the card and mistakenly checked the box to preserve the associated sprints. How do I now delete all the associated sprints?
This does not appear to be working anymore (in Jira Cloud, at least), leaving us with no way to remove an issue from a closed sprint. Atlassian?
From what I've read in related threads cloning the issues and choosing to not-preserve sprint information may be a workaround for some scenarios.
From what I've read in related threads, cloning the issues and choosing to not-preserve sprint information may be a workaround for some scenarios.
I agree - I followed the steps from Geoffery Rogers and only the current sprint was cleared *not* the "Completed sprints". I think I will be cloning my issue (without sprint data) and deleting the original as a workaround
I did a bulk edit and assigned ID of current sprint, which replaced all the sprints assigned (it had a current sprint and old finished sprint assigned at that time). It works. Though, cloning should really not clone Sprint label if it's finished...
Kamil's solution worked.
I could not get rid of the completed sprint by bulk editing and leaving the sprint field blank but by bulk editing and setting the sprint field to the id of a current sprint it worked.
I was able to remove the closed sprints from the ticket by using Bulk edit step described above (assigned new sprint ID) and the current sprint was added successfully but the ticket is still not visible on the current sprint board. any idea?
Majority of the time when i run into this, its due to someone selecting the same Sprint Name that exist's in a separate project.
I validated all the points above and none of them is valid.
Just to clarify, I can see the main ticket on the sprint board but not its subtasks that were automatically assigned to the sprint of their main (parent) ticket. The subtasks are not even visible on the backlog. The only way to access those subtasks is to open the parent task.
On the Step 3 "check the box..." you have to fill out the Sprint field with the number (which is the Sprint ID).
You probably put the Sprint name into it - not the ID.
To find the ID of the Sprint name you need to use Issue Navigator (From the menu bar: Isues -> Search for issues). Try to find your Sprint name with this query: "Sprint = MySprintName". The issue navigator will show you the name of the searching Sprint with the ID in brackets.
Other way to find the ID of the Sprint is to search for it in Database Table Sprint
@Krzysztof Niewinski You would only enter the Sprint ID/Name if you wanted to assign the sprint to the selected issued (in the bulk edit flow). The original question was how to *clear* the sprint information. To do that, you would simply check the box and leave the field blank.
It doesn't work when I leave it blank, it completes all 4 steps successfully but it doesn't have any effect on the tickets. they still have their old sprint value
Yes, this used to work. I just tried it again today and it isn't working so maybe this bulk edit workaround doesn't work any longer :(
For Jira cloud, export (all fields) and you will see multiple sprint column (BK, BL...)
take the last sprint ID value and put it in column BK (or put an other active sprint that can be messed with)
clear other columns
reimport
Assign the issue to a future sprint (without affecting your planning) through bulk edit and then open the issue to remove the newly assigned sprint.
Assigning to a future sprint should be done only through bulk edit as it replaces the old sprint value. Do not try to assign the sprint by opening the issue as it assigns the issue to multiple sprints.
This worked for me.
This does not work for me. My issue is associate with our current (open) Sprint, and with a closed Sprint. I want to assign it to the current Sprint only, and remove it from the closed one. Using the Bulk Edit functionality, I encounter the following Exception:
Please contact the administrators, and inform them of this bug. Details: ------- org.apache.velocity.exception.MethodInvocationException: Invocation of method 'convertEditValueToObjects' in class com.atlassian.greenhopper.customfield.sprint.SprintCFType threw exception com.atlassian.jira.issue.customfields.impl.FieldValidationException: Sprint id must be a number: DEV Sprint KW 50 + 51/2014 at com.pyxis.greenhopper.jira:gh-sprint//templates/greenhopper/jira/customfield/sprint/edit-sprint.vm[line 3, column 57] at org.apache.velocity.runtime.parser.node.ASTMethod.handleInvocationException(ASTMethod.java:337) at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:284) at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262) at org.apache.velocity.runtime.parser.node.ASTReference.value(ASTReference.java:507) at org.apache.velocity.runtime.parser.node.ASTExpression.value(ASTExpression.java:71) at org.apache.velocity.runtime.parser.node.ASTSetDirective.render(ASTSetDirective.java:142) at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336) at org.apache.velocity.Template.merge(Template.java:328) at org.apache.velocity.Template.merge(Template.java:235) at org.apache.velocity.app.VelocityEngine.mergeTemplate(VelocityEngine.java:381) at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBodyImpl(DefaultVelocityManager.java:117) at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBody(DefaultVelocityManager.java:97) at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.toWriterImpl(DefaultVelocityTemplatingEngine.java:146) at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(DefaultVelocityTemplatingEngine.java:134) at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.writeHtml(AbstractJiraModuleDescriptor.java:150) at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.getHtml(AbstractJiraModuleDescriptor.java:119) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl.getHtml(CustomFieldTypeModuleDescriptorImpl.java:363) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl$1.call(CustomFieldTypeModuleDescriptorImpl.java:197) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl$1.call(CustomFieldTypeModuleDescriptorImpl.java:188) at com.atlassian.ozymandias.SafePluginPointAccess.call(SafePluginPointAccess.java:187) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl.getSupplierValueOrHtmlErrorMessage(CustomFieldTypeModuleDescriptorImpl.java:433) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl.getEditHtml(CustomFieldTypeModuleDescriptorImpl.java:187) at com.atlassian.jira.issue.fields.CustomFieldImpl.getEditHtml(CustomFieldImpl.java:1100) at com.atlassian.jira.issue.fields.CustomFieldImpl.getBulkEditHtml(CustomFieldImpl.java:1149) at com.atlassian.jira.web.action.issue.bulkedit.BulkEdit.getFieldHtml(BulkEdit.java:101) at sun.reflect.GeneratedMethodAccessor2563.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70) at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56) at webwork.util.ValueStack.findValue(ValueStack.java:517) at webwork.util.ValueStack.findValue(ValueStack.java:216) at webwork.view.taglib.WebWorkBodyTagSupport.findValue(WebWorkBodyTagSupport.java:62) at webwork.view.taglib.BasicPropertyTag.doStartTag(BasicPropertyTag.java:54) at org.apache.jsp.secure.views.bulkedit.bulkedit_005foperationdetails_jsp._jspx_meth_ww_005fproperty_005f10(bulkedit_005foperationdetails_jsp.java:1841) at org.apache.jsp.secure.views.bulkedit.bulkedit_005foperationdetails_jsp._jspx_meth_ww_005felse_005f2(bulkedit_005foperationdetails_jsp.java:1812) at org.apache.jsp.secure.views.bulkedit.bulkedit_005foperationdetails_jsp._jspx_meth_ww_005fiterator_005f0(bulkedit_005foperationdetails_jsp.java:1551) at org.apache.jsp.secure.views.bulkedit.bulkedit_005foperationdetails_jsp._jspx_meth_ww_005fif_005f2(bulkedit_005foperationdetails_jsp.java:1484) at org.apache.jsp.secure.views.bulkedit.bulkedit_005foperationdetails_jsp._jspService(bulkedit_005foperationdetails_jsp.java:255) at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:386) at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:313) at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:260) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:32) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:40) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCommonFilter.preventDoubleInvocation(PrettyUrlsCommonFilter.java:38) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:24) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCommonFilter.preventDoubleInvocation(PrettyUrlsCommonFilter.java:38) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:74) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:30) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:66) at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:85) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172) at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.bonfire.web.filters.BonfireP3PFilter.doFilter(BonfireP3PFilter.java:43) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:646) at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:436) at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:374) at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:302) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.forwardToHttpView(JiraWebworkViewDispatcher.java:125) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.dispatchViaHttpView(JiraWebworkViewDispatcher.java:105) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.dispatchView(JiraWebworkViewDispatcher.java:74) at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:204) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:40) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.studio.core.servlet.filter.AlacarteLicenseEnforcer.doFilter(AlacarteLicenseEnforcer.java:86) at com.atlassian.studio.jira.servlet.filter.AlacarteLicenseJiraEnforcer.doFilter(AlacarteLicenseJiraEnforcer.java:130) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85) at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(PageBuilderFilter.java:89) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(CommittedResponseHtmlErrorRecoveryFilter.java:62) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.plugin.connect.plugin.scopes.ApiScopingFilter.doFilter(ApiScopingFilter.java:113) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172) at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.bonfire.web.filters.BonfireP3PFilter.doFilter(BonfireP3PFilter.java:57) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.core.filters.ServletContextThreadLocalFilter.doFilter(ServletContextThreadLocalFilter.java:21) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99) at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:88) at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:59) at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.plugin.connect.plugin.threeleggedauth.ThreeLeggedAuthFilter.doFilter(ThreeLeggedAuthFilter.java:107) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.plugin.connect.plugin.module.oauth.OAuth2LOFilter.doFilter(OAuth2LOFilter.java:82) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40) at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jwt.plugin.servlet.JwtAuthFilter.doFilter(JwtAuthFilter.java:31) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:60) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190) at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291) at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:776) at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:705) at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:898) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690) at java.lang.Thread.run(Thread.java:745) Caused by: com.atlassian.jira.issue.customfields.impl.FieldValidationException: Sprint id must be a number: DEV Sprint KW 50 + 51/2014 at com.atlassian.greenhopper.customfield.sprint.SprintCFType.getSingularObjectFromString(SprintCFType.java:114) at com.atlassian.greenhopper.customfield.sprint.SprintCFType$2.apply(SprintCFType.java:242) at com.atlassian.greenhopper.customfield.sprint.SprintCFType$2.apply(SprintCFType.java:238) at com.google.common.collect.Iterators$8.next(Iterators.java:812) at com.google.common.collect.Lists.newArrayList(Lists.java:139) at com.google.common.collect.ImmutableList.copyOf(ImmutableList.java:256) at com.google.common.collect.ImmutableList.copyOf(ImmutableList.java:217) at com.atlassian.greenhopper.customfield.sprint.SprintCFType.convertEditValueToObjects(SprintCFType.java:237) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:483) at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.doInvoke(UberspectImpl.java:385) at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.invoke(UberspectImpl.java:374) at com.atlassian.velocity.htmlsafe.introspection.UnboxingMethod.invoke(UnboxingMethod.java:30) at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:270) ... 349 more
