This question is in reference to Atlassian Documentation: Working with epics
Two cases in which I need this ability:
Thanks for any help!
Those docs have changed.... here's the answer:
You will need to change the Epic Status field from Done to In Progress. Here's how I was able to do it without being some kind of Jira wizard:
Thank you!
Thanks for this information! I did this but then had to figure out how to remove the field once I edited the EPIC Status. I went to my view issue screen and removed the field again from field configuration
Whoops! The answer is hidden under the "Tips" section of the Working with epics page above.
