Status, resolution, type, etc. doesn't matter. I want to find every task in the system that has subtasks associated with it.
You can achieve this using a plugin like script runner or JQL Search Extensions for Jira & reports
I am using JQL Search Extensions for Jira & reports and following query will fulfill this need if you use the same plugin.
It will return all issues which at least have one sub task
issue in subtaskCountGreaterThan(1)
with Scriptrunner
issueFunction in hasSubtasks()
More info in https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_hassubtasks
issuetype in subtaskIssueTypes()
will display subtasks and the parent as well
Save your spot
