×Hi there! I work on a Procurement team that leverages JSM for our approvals and contract negotiation process.
Using the data in our contract lifecycle management (CLM) system, on a monthly basis, we export expiring contracts, transform the data for Jira and then bulk import "Renewal" issues into our JSM project. This includes importing w/ a standard configuration file -> bulk changing issue type + request type.
The issue is, Jira doesn't notify the "Reporters" we've identified when these issues are created. We can't create an automation for that specific request type since folks occasionally submit it on their own, for various reasons.
What's the best way to notify a reporter that a request has been bulk-imported on their behalf? Would the "Send email for this update" during the bulk change (second part of the process) suffice? Or is there a better automation I can setup for this?
Thx in advance!
Hi Amy,
1.When you're bulk importing tickets, you can include a column titled Labels and add a value, such as "CreatedfromCSV". This label will serve as a differentiator for the tickets created through the import versus those created by users.
To automate a notification process, you can set up an automation rule as follows:
2.Or you can use "Send email for this update".
Hi Cristian,
The import will not cause the Automation rule to fire. Otherwise there is no reason to add the label.
https://jira.atlassian.com/browse/JRACLOUD-81955
@John Funk can you elaborate on why an import would not trigger the automation? The issue is still created with the label, isn't it?
Asking because I like @Cristian0791 's approach since it also creates an auditable record of which issues were imported vs which are submitted by Reporters.
Unless there is another way to identify this?
Greetings!
That defect from September 2016 seems out of date as importing a CSV file to create issues does generate the issue-created event and will trigger an automation rule. I just tested to confirm this with both paths to import with a company-managed project rule:
Automation update:
This should catch only the tickets with label: CreatedfromCSV
Ahhh great! We run the next import next week so I'll come back with an update.
@John Funk I think Jira pushed several import features ~4-6 weeks ago (i.e. they removed the import option from the create-issue screen), could have been then?
This is all super helpful - thanks so much, everyone!
Hi Amy,
I would suggest you do a sample import with just a couple of issues. Check the box to send the email and see if the Reporter gets notified. But makes sure you use a different user for the Reporter than yourself so that it doesn't get caught by other rules.
Let us know how it goes!
@John Funk this would not be ideal because we have several approvers and stakeholders in our process and would be triggering false notifications to Executives, other teams, etc. which we don't want.
