How do I set up milestones in a plan?
@mahesh_kalla Welcome to the Atlassian community
You will need to work with your Jira admin to make this happen. They will need to create an issue type of Milestone and ensure it is associated with your project(s) that you would like to use it in. Then you will need to configure custom hierarchy levels in your plan. https://support.atlassian.com/jira-software-cloud/docs/configure-custom-hierarchy-levels-in-advanced-roadmaps/ You can then group work into those milestones on your plans.
Hi @mahesh_kalla , welcome to the Atlassian Community and thanks for your post.
Please check out this other post where someone is asking the same question https://community.atlassian.com/t5/Jira-questions/Milestone-markers-in-Jira-Roadmaps/qaq-p/2261049 .
Basically, it's not possible to have Milestones yet but you can vote on and follow the suggestion here https://jira.atlassian.com/browse/JRACLOUD-91595
Best wishes
Hey @mahesh_kalla you can use our app (Visor) to create plans, Gantt charts, roadmaps and other visualizations with milestones, all using your real-time Jira data.
Visor has a bi-directional Jira integration, so your plans always stay up-to-date with any changes in Jira, and you can sync changes back from Visor to Jira too.
You can try Visor for free now, so take a look at us and our reviews in the Atlassian Marketplace to get started:
I've also added some images of Jira plans in Visor, with those clear milestones you want, hope you like Visor!
