Hi All,
please could you help me with complexity problem in JIRA regarding managing one common product backlog for more teams (3 Sprints backlog). Distribution user stories from one product backlog to 3 sprint backlogs (3 countries with different responsibilities for development particular system).
Many thanks, James
Hi Gaston,
Many thanks for your advice! Yes, it is exactly what I am looking for. Based on your very beneficial recommendation I setup JIRA (result please find attached below), make sense this way from your perspective? I am still looking for better tagging/labeling stories (than re-use Versions, Epics for different purpose) and also mainly way of evaluation sprints between sprints (I am not sure that Velocity chart will work for every Sprint backlog).
Do you know this Portfolio Add-on (https://www.atlassian.com/software/jira/portfolio) or please do you have any other ideal how to manage this?
Many thanks,
Jakub
image2017-3-14 18:56:52.png
Jakub, how are you labeling stories right now? and how do yo manage sprints between sprints?.
Our teams set up is a little different. We have several products and all teams can work on any product's stories/features (whatever is the higher priority for the company at the moment), this is in accordance to LeSS.
Because of this, the filters for our teams' boards all import tickets from multiple projects (JQL is something like project = X OR project = Y ... etc). Each project has a different PO that has set up their projects using the specific workflows for their products. Some of these workflows have different Definition of Done, and other differences.
The problem arises, when one team's board needs to show tickets from different projects on the same sprint. If you set up the columns for one project's workflow (associating columns to statuses), you might be messing up the association for the other project, since they have different workflows.
Has anyone else encountered this problem?
Yes - we had a Design team that did work which may or may not make it to a development team. In the Design team workflow, we tried setting up entrance and exit points between boards. It became too cumbersome because we essentially added 2 extra columns like an Inbox and Outbox, where each team could see each other's Inbox and Outbox, but not the In Process column in between - but this isn't sustainable if you have 1 project workflow integrating multiple other projects - too many columns.
I was hoping to find some improvements in Automation of Moving issues, but so far it seems you can only auto-clone to a different project, then auto-delete in existing.... https://support.atlassian.com/jira-software-cloud/docs/move-an-issue-with-automation/
This may not be bad though - perhaps just don't delete the original, and auto-comment back to the original when complete? I'll have to try it.
A completely different way (and my preferred way, but political) is to re-organize the teams by Business Objective instead of org chart / product. The intention is to better address cross-functional issues, and cut down on dependencies across teams, while better aligning to Vision-Mission-Strategic Objectives.
Hi Thomas, thank you, probably I am looking for little bit different approach as Gaston wrote below. I will be glad if you have any other recommandation for this approach parallel sprints. Thanks, Jakub
Have you dug into the Swimlanes yet? Swimlanes allow users to use one board for multiple projects such as backlogs. Is this what you are looking for? If so, I can explain more
