How do I show number of issues reported by user?
Joe Murray
How could I create a dashboard report that shows the number of issues reported by user? If it is not available in that manner, can I produce it some other way?
Nic Brough -Adaptavist-
September 30, 2014
Create a filter for all the issues you want to look at, and save it with a descriptive name.
Go to your dashboard and add a "filter statistics" gadget.  It will ask for some data:
  • For filter/project, choose your saved filter
  • You probably want to "include resolved issues"
  • Select "Reporter" as the statistic
  • Ignore the other parameters for now
Udo Brand
September 30, 2014
Good answer +1. But the gadget is called "issue statistics"
September 30, 2014
Do'h! Oh well.
Joe Murray
Agree with Udo, which took me a little time to figure out. In the meantime I had found the Two dimensional filter statistics gadget and managed to get it to work with x-dimension being status and y-dimension being Reporter.
October 1, 2014
The 2d filter is really useful, and probably why I got the name wrong!
