I'm experimenting with different types of templates that might fit my projects. I have Scrum up and working fine but for some folks/projects the 'Project Management' template seems to fit better.
I noticed that subtasks do NOT appear while the Board view. I would like subtasks to appear directly below the parent task in the Board view as it does in Scrum. Any solutions?
note: I just noticed that documentation explicitly states that subtasks are not visible for a project management board. If that point still holds then this issue should be close.
