I have some Closed Test Cases that are children of User Stories, but also linked to the Epic. I want to unlink them from the Epic, but can't figure out how.
I found the solution for this @Mark Johnson.
1-) Go to Issues.
2-) Filter the by Type: "Test" and Creator: "yourUSER". (look for the set of testcases you are trying to remove).
3-) Click on Tools (It is on the top and right side).
4-) Select All XXX issue(s).
5-) Check the testcases that you are willing to remove from the EPIC.
6-) Click Next
7-) Cherck the "Edit Issues" radio button.
8-) Click Next
9-) Check "" and leave the Dropdown empty (DO NOT WRITE OR SELECT ANYTHING HERE)
10-) Clcik Next
11-)Confirm.
How do you get the TestCases to be seem on the Rapid booard?
i'm only able to see Stories and Bugs.
A couple of ways to remove an issue from an epic:
