How do I unlink the sprint label across multiple projects
John Kaplan September 23, 2014
I have two projects that have an active sprint with the same identifier number. Now when i change the label for one sprint in one project, it changes the label for a sprint in another project. How can I change the name of one of the sprints and not have it affect another sprint?
John Kaplan September 29, 2014
Hi Zan,
Here is the issue I filed, but it was set to resolved as it is known behavior:
https://jira.atlassian.com/browse/GHS-11250
I think I will have to re-submit it as an improvement request.
-John
Zan Buchanan September 29, 2014
Hi @john kaplan] and [~elisa diel [atlassian] I agree with John, this shouldn't be marked as resolved. I've posted a comment on the issue referenced as well.
Jason Smith December 18, 2014
This causes big problems for us... Most groups only have access to their project, and they create names like "Sprint 1" and so they step all over each other and then complain when they don't have access to close the sprint. It creates a huge support/administrative mess.
Dale Matthews November 15, 2016
Hi - is there a resolution for this yet? I am having same issue.
Cheers.
Zan Buchanan September 28, 2014
I have the same problem - I have two projects but since running sprints in each the numbering has gone out of sync when I try searching in filters.
@John Kaplan do you have the issue number you raised?
Tx,
Zan
John Kaplan September 26, 2014
Hi Elisa,
I raised an issue, trying to work through it now.
Thank You!
Elisa [Atlassian]
September 26, 2014
Sure thing! :)
Elisa [Atlassian]
September 25, 2014
Hi John,
We might have to change it directly on the database. Could you please raise a ticket on Atlassian SAC (support.atlassian.com) under JIRA Cloud so we can better investigate it? smile
Cheers!
