How do I update existing issues using the CSV importer for JIRA OnDemand
Robert Jacobs
The Importing Data from CSV - Atlassian OnDemand Documentation reads:
Updating existing issues
From version 4.3 of JIRA Importers plugin you can update existing issues. Your CSV file needs to contain a column that during the import wizard is mapped to Issue Key. If an issue exists for a given key it will be updated.
I have tried this and there is no Issue Key to map to.
6 votes
Robert Jacobs
I have have found a workaround. Under JIRA Administration > System. Under IMPORT & EXPORT > External System Import select Import from Comma-separated Values (CSV). This wizard includes the 'Issue Key' in the field selection dropdown.
VP
October 5, 2014
Thanx - Very helpful input! This should be implemented in the official Atlassian support documentation
Like # people like this
JeffM
February 7, 2016
Hi, Thanks! Been looking everywhere for a resolution to this. My problem was using the "Import Issues from CSV" option from the issues drop down, this does not have the Issue Key field as an option. Didn't bank on there being different import options from different menus! Thanks for the workaround!
Zul NS _Atlassian_
March 14, 2016
Note that CSV import for users in Issues > Import Issues from CSV is limited to creating issues as per its respective documentation in https://confluence.atlassian.com/jira/creating-issues-using-the-csv-importer-636420874.html
https://confluence.atlassian.com/jira/importing-data-from-csv-185729516.html is for the administrator as you can see the page location in the page tree on left-side.
Like Sowbarnika M likes this
M Vijay Kumar
Hi Thanks for the information. The documentation says updating of the existing issues from JIRA version 4.3 and above. Would like to know is there any difference for the cloud versions of Jira.
Shalvika Sood November 11, 2016
Hi, I am actually using the steps above BUT by mapping the Issue Key and Summary I am getting an error that the issue already exists! it's not updating
I am using the External System Import
Like Lucy Buecking likes this
david.l.silva
August 15, 2017
I see the same thing as Shalvika Sood Anyone know why this is happening?  Did the update functionality get deprecated?  I am using v6.2.6#6264-sha1:ee76422
Scott Bassett
November 26, 2019
+1 for this thread, was able to use external system export to update issues. I was trying to add a custom field value, selected "Issue Key", my custom field and checked the box for "Map these fields to Jira" then it did make me select "Summary" in the drop down but I didn't select the box to the right. It seemed to work and do what I needed it to though!
Ashish_Ranjan
November 27, 2019
+1. Successfully Update existing issue if I upload with "issueKey" field in csv from "JIRA Administration > System. Under IMPORT & EXPORT > External System Import".
Just wanted to know, why this is not available from "Create > Import issues"?
Scott Hassell January 25, 2021
update existing issues.pngHello,
I have recently tried to update existing issues from a Jira file using the system Import external system.  The debug log says it didn't import because the issue already existing.   I do have a  issuekey, summary columns in my csv with the number of the existing Jira issue.  Any ideas how to solve?
Ryan DeBoer
April 2, 2021
I have the exact same problem. If anyone has any recommendations here on how to fix this that would be great!
Like VP likes this
Michael Geppert
April 15, 2021
I have the same problem,
Like VP likes this
John Monts April 23, 2021
you need to map import file issue key to issue key .. when you do you will see:
You have selected Issue Key mapping. Please note that importer will update existing issues matching the Issue Key from the CSV file.
Cassy Arretche
May 26, 2021
Same problem trying to update existing issues. Mapping Issue Key to Issue Key from the external system import and the desired fields (mapped) will not update.  Any recommendations on how to fix this?
Nic Brough -Adaptavist-
August 27, 2014
Eh? Look at one of the issues you want to update. The issue key is now on the screen in front of you next to the summary and it's in the URL as well. The bit that says project-number (JRA-123 or whatever)
Robert Jacobs
Nic, I have identified the keys of the issues I want to update and they are listed in the CSV file but there is no option to map to them in the import wizard. There is no JIRA field for Issue Key.
Nicola Barton May 5, 2015
Hi, did you ever get to the bottom of this? I'm having the same problem!
May 6, 2015
He was looking at the user importer which only allows for "create" and hence doesn't need issue keys He's solved it by using the Jira Importer which supports updates when given an existing issue key
May 6, 2015
Oh, that was badly written. By "user importer" and "Jira importer", I mean there are now two CSV importers available. The user importer is available to normal users, but the Jira importer is for admins only.
Nicola Barton May 6, 2015
Ah, I made the same mistake. I've found it, thanks!
Eugene Yasiuchenko
@Robert Jacobs2  Where have you found 'admin' importer? Can you please specify it step by step? Having problems with it..
thank you!
vitaliy zapolskyy August 22, 2018
  • to access admin importer
    Log in to JIRA as a user with the JIRA Administrators global permission.
    Select Administration > System > Import & Export > External System Import.
Les James September 27, 2018
@Eugene Yasiuchenko as @vitaliy zapolskyy pointed out the location of the Admin External Import. Just remember if you are updating that the importer requires a summary field however the summary does not need to be mapped (leave it unchecked). As long as the issue key exists, it will update those tickets.
Satheesh Kumar Srinivasan
I'm getting below information while i try to update the existing issues in Jira with new values.
"while updating issues have been skipped because they already exist in destination projects."
Please let me know why i get this error. I'm Jira administrator. Below are the steps i follow:
In Jira settings --> System --> Import and Export --> External System Import -->
1. I get Jira Import wizard
2. I selected CSV
3. I got new page as CSV file import. Here i have File import and i uploaded the CSV file which i prepared. (Note issue key and all details are available. My aim is to change the Story points in each issues to a new value in Jira using this bulk option)
4. I map in the next page "Fields" only the Issue key and Story points.
Output is what is mentioned in the first line.
Request to guide me in steps (micro level) so that it can benefit everyone.
Thanks in advance
Renato Chencinski
Anybody knows a way to update specifically the issue key using csv? I'm using external import for trello (so comments and a bunch of info gets imported), but issue key is not kept the same as trello, which is bad.
I've tried updating the issue key, using issue id, but no luck.
Jason_Ashley
June 24, 2020
Have spent hours trying to find out how to update an existing issuekey, tried several ways without getting expected results. Such a common scenario, yet no easy solution found.
Like Lazhar Sellami likes this
Piyush A (STR)
January 9, 2023
Update via CSV - triggers email notification?
Like VP likes this
