How do I use a quick filter?
Simon Hancock October 18, 2023
Hi, I am trying to create a filter within JWM for a group of components. I have created the filter and saved it but I then cannot see it anywhere within JWM. If I drop down the options from the filter there is no option to choose a created one? Can anyone help please?
Asmath Basha S
October 19, 2023
Hi @Simon Hancock  Can you share a screenshot of the filter and the field which you have mentioned above.
Brant Schroeder
@Simon Hancock Are you creating the filter from the filters menu at the top of the page?  Or are you creating a filter in a Queue?
I am assuming creating a filter from the menu at the top, if this is the case where are you trying to find it in JWM?
Register today
