How do I use story points with green hopper and jira?
Chris Fontan July 1, 2013
I have greenhopper 6.2.3 and jira 5.1
I have added story points to the default screen configuration but it does not display there when creating/editing a story. It also does not display story points field from within greenhopper even though I have configured the scrum board to use story points under the estimation tab.
Raju KC
July 1, 2013
Make sure this field is available in both Screen Scheme and Field configurations.
For Field Configurations:
Admin->issue->custom fields->story points->configure->
made it available for story/epic issue type.
Similary check for screen scheme
Thank you this resolved my question!
"Admin->issue->custom fields->story points->configure->
made it available for story/epic issue type."
Christian Czaia [Decadis AG]
July 1, 2013
You might want to accept ck's answer if it solved your question :-)
Register now
