×HI,
We use jira cloud version.
We want to add group for watcher.
What should we do?
Hi @JaeSeok_Go
Welcome to the community!
Nope, you can not.
You need to add as an individual user only.
To anyone coming to this late and using Jira Cloud, consider using an automation!
You can trigger it from the ticket and add a specific list of people.
Hi @JaeSeok_Go
there are few post function provided by 3rd party plugins which can help to add users from project role or group or group picker field.
1. Add or remove watchers by JWT Adds or removes issue watchers based on custom fields or project roles.
2. If none of them are installed you could do it outside JIRA using REST api
Rahul
Hi @JaeSeok_Go
Go to Permission Scheme of that project and edit the Manage Watchers Edit Add the group
