How do i change JIRA 7 port 8080 to port 80
Jesse Callejas January 8, 2016
I already did the change in the server.xml file, and even went into the Admin --> General Settings --> Server Base URL and change the port there as well, and nothing. When I do the changes and try to connect to JIRA, the browser stays trying to connect for a very long time and it cannot connect. JIRA is currently installed on windows server 2012. I'have read thing like using a proxy. If that is the case how would I do it in Windows? Thanks in advanced and all your help, for little that it may appear, is totally welcome. Thanks.
Jesse
Deleted user January 8, 2016
Try to update the server.xml in the installation directory.
Reference: https://confluence.atlassian.com/jira/installing-jira-on-tomcat-6-0-or-7-0-185729501.html
Jesse Callejas January 11, 2016
Thanks Gabrielle, I did the changes one more time and it did not work. I was about to open a support ticket with Atlassian, however I did not give up, and went ahead and do the changes one more time, and this time for some "Unknown" reason it took the changes, and it worked. Totally weird: "I must say that JIRA works in mysterious ways". Thank you.
Deleted user January 11, 2016
Glad to have helped! Sometimes, a "hard refresh" of your browser is needed to pickup the changes.
