How do i delete a project?
baruch ostrovsky
This question is in reference to Atlassian Documentation: Setting up your service desk
5 votes
mohd zakir
Hello everyone,
Project delete option you can find by 2 ways
1) Go to setting => Projects => Delete
See the screenshot below
2)Go to project => Delete project
See the below screenshot
Susan Barney
June 22, 2018
Thanks!  That worked!  :)
Mediapro US July 17, 2018
Thanks.
David Abdel-Malek
September 5, 2018
This does not work. I tried both suggestions but I still see the project in the admin list.
Like # people like this
Katie Fong
April 18, 2019
Thanks, this was helpful and it worked for me.
AKSHAY KUMAR
September 10, 2019
Thanks , That worked ! :)
4 votes
Nic Brough -Adaptavist-
January 10, 2016
Log in as an admin, and either
  1. go to the project, find the admin section and select "delete project" from the options at the top right.
  2. go to the admin's list of all projects (not the plain user project list) and select "delete" from the options to the right of the project
Bear in mind that deleting a project kills it completely.  If you have any doubts that you may need any of the data in it again, take a backup first, because that's the only way of recovering it.
Radha Chhuttani
I am not able to find admin tab and then delete tab
Jolene Hey
At the very top-right is your avatar icon. Next to that is a cog (gear) icon. Click the cog.
The dropdown says JIRA ADMINISTRATION.
Choose Projects in that list.
The Actions column in the Project row will have a delete link.
David Alperovich
@Jolene Hey, at the top right gear Icon only gives me some option to hide something.
My avatar is on bottom left. There is an Administration section, but it has no entry related to projects or deleting them. There is no JIRA ADMINISTRATION option, and yes, I am every kind of Administor (and I'm also the owner of the account)
Ian Franks
October 4, 2019
Same problem for me. Icon is bottom and no option to delete projects!! Very frustrating having so much difficulty to do something that should be so simple!! :s
Like Elie Abouzeid likes this
Lepanto
June 19, 2019
I don't see delete option in sidebar of project settings.
But found delete option in project settings >> details page by clicking three dot on top right
Brett Wyrick
Looks like this is a next-gen project.
Sibusiso Maluleke May 16, 2018
Go to your DASHBOARDS ---> Click on SETTINGS ---> click on PROJECTS --->click on PROJECTS again ---> the Vwalaaa you can see the DELETE option there to click on.
Tadd Barnes
September 5, 2019
Got to love the usability in Jira.  This worked for me!
Andrea_Coppo
March 13, 2020
Ok. That worked. Thanks a lot
Wallace Mann March 28, 2019
Wow.  Pretty frustrating.  I have a brand new cloud instance of Jira and I am the admin and only user.  None of these suggestions help.  I've been around and around and around and don't see any option to delete.  My screens do not look like the screen shots above.
I am very familiar with Jira but new to being an admin.  My assumption (as also described above) is that by default I don't have the right permissions.
Bad UI design aside, can someone provide advice to getting god-like privileges on Jira so I can do this (and whatever else might come up).
Wallace
March 28, 2019
That's because the screenshots are of an old version (Server is still similar to them), as you might expect on a 2-3 year old question.
Go to the project details (in project settings) and look to the top right, where there is a ... menu with "delete" as an option.
Wallace Mann April 1, 2019
Thanks, Nic.  The "project details" was the key to get me there, although I found it in a different spot.
I do not know how much my Friday attempt to grant myself as many privileges as possible might also have made the difference ... I don't know if some permissions take time to come into effect.
For completeness in case anyone gets as lost as I did, this was my path to the light:
(1) Found my list of projects
(2) Clicked on the project to be deleted and came to the menu below.  I think I got tripped up before because this list disappears when minimized.
(3) By clicking "Project Setting" I came at last to the golden button to delete the project.
IT Manager
Crikey, that was difficult. So many out-of-date posts on this topic and not much direction from Atlassian staff. Thanks @Wallace Mann , your instructions were spot on.
Good luck to those finding their way here in 4 years ;)
Ian Franks
October 4, 2019
Perfect!
I got there in the end thanks to your screenshots.
Many thanks.
Matthew Krudop
January 24, 2019
This is a bit frustrating as the instructions are vague and the UI confusing.  Assuming that you get into the project settings, the left panel becomes a menu bar (hidden in plain sight).  On this menu bar, there is a delete project option.
Elamaran Police
November 7, 2018
Open the project and then click on Project Setting. There you will get option to delete the project
Ton June 21, 2018
David Alperovich
very odd, the option was missing, and suddenly it became available. The only explanation is that even though I am account owner, I didnt have the right privileges by default and after I added them, they still didn't take effect until much later.
No wonder everybody has problems. The system is set up by default for account owners not to have the right settings.
Susan Barney
June 22, 2018
How did you set up the right settings?
Duncan Grant
February 26, 2020
If the question has to be asked, then JIRA you have done something wrong.
Brett Wyrick
For JIRA Cloud:
Open the sidebar (shortcut is '[' ), and click on "Project Settings".
On the "Project Settings" page, "Delete Project" is on the sidebar.
It was confusing that it wasn't on the bottom. Usually, deleting things seems to be at the bottom of most user interfaces. It's also odd that you can't delete a project in the Project List.
Hope this helps someone.
mohd zakir
After selecting delete,  it will ask for, "you are about to delete"
Screenshot_11.pngClick the Delete button, it starts deleting project and then it will generate acknowledge
Thank You.
Me too I cannot find the admin TAB, this is so not helpful.
May 16, 2018
Nevertheless, it is a correct answer.  Since it was written, Cloud has had the UI changed to something that makes it a lot harder to find stuff, including the admin sections.
Look for the settings cog on the left to start with, while you're in a project view.
Thank you Nic, I will keep trying, if I find it I will post it.
SO I FOUND HOW.
David Alperovich
@Nic Brough -Adaptavist-, my avatar is on bottom left. There is an Administration section, but it has no entry related to projects or deleting them.
At the top right in a project, there are the dots in a grey box, but clicking on them only gives me an option to "Hide cover image", whatever that means.
May 21, 2018
In the admin section, go to the list of projects, that will have the delete option
Like Viren Kochhar likes this
