×I created a custom field and i need to add multiple issue types to it. When i used a PC i would hold shift to select multiple issue types. Is there a way to do this on a macbook pro?
Hello @Shawn Wallace,
In order to select multiple issue types when editing the “Choose applicable issue types” on a custom field, you can use Control + Shift + Down. In case you want to select some of them, you can hold Command + Click on each one you need.
If that’s not what you meant, please let us know more details of the steps you are following, so we can test the same here.
Angélica
This solution is not working with the macbook Pro keyboard. If I press command and click the different options I would like to select, you can just activate another "scroll mode" with the magic mouse. Is there another short cut to select various non-consecutive options in a drop down menu in a Feature?
If it's helpful, I can send you some screenshots if you have a mailaddress for me. :)
There is no command key i can find anywhere in my keyboard.. tried few thing and found out ctrl+alt worked when selecting specific issue type for field.
