×Adding custom fields to the Plan's Field section to display the value in a column works great. I have a user asking for a system field, like Fix versions, to be added so they can review it on the plan in a column. Can this be done, and if so, how? Thanks
Fix Versions field in the Plans view is called Releases. Please, add the field at your Plans view.
Hope this works for you
Fernando
@Fernando Eugênio da Silva: That worked perfectly! Thank you! I wish Atlassian were consistent in naming releases vs. versions.
Don
