How do you change "Summary" field name using Scriptrunner?
Connie Leuderalbert May 6, 2021
I saw a previous post that this was possible by @Tuncay Senturk.  I am new to Scriptrunner, is anyone aware of code I could use to do this?  Thanks.
Connie
7 votes
Tuncay Senturk _Snapbytes_
Thanks for reminding, here are the steps defined below:
  • Go to Behaviours section of the Script Runner.
  • Add a new Behaviour (name something and click on Add)
  • Click on cog icon and map this behaviour to a project or issue type, anything you want accordingly.
  • Click on cog icon and Edit
  • Select Summary in Add Field dropdown.
  • Use the script below
    def field = getFieldById(getFieldChanged())
    field.setLabel("Renamed Summary Field")
  • That's it
I hope it helps,
Let me know if you need clarification.
Tuncay
Connie Leuderalbert May 7, 2021
Thank you!  That did just what I needed it to do!
@Connie Leuderalbert but you've marked the other answer as accepted :)
@Tuncay Senturk _Snapbytes_ who knew accepting answers could be so complicated.  I fixed it!  Thanks again for the help!
You're very welcome :)
Alexander Bondarev
May 6, 2021
Hi, @Connie Leuderalbert ,
What do you want to achieve with this?
The purpose is to rename the summary field.
Alexander Bondarev
May 6, 2021
For what? 🙄
Hi @Connie Leuderalbert
Sorry for my memory!
Which post is that? :)
SERVER
Help us plant more trees
