×I had an issue where a JIRA portfolio plan had data corruption.
I'd like to create a copy of it as backup in the future as well as create one as a template base for future plans. I don't want to have to re-enter all the team information over and over again.
Any suggestions?
Hi Bonnie, you can use the Plan XML export for this: Plan > Export.
For re-importing the plan, you can do it via the Plan Creation Dialog Portfolio > Create Plan > Import from a File (link at the bottom of the dialog)
The re-import will not influence the existing plan, but basically creates a new plan based on the exported data.
image2015-11-25 9:40:48.png
This post,
seems to indicate that this XML export/import solution no longer works. Am I reading this correctly and, if so, is there any plan to restore the ability to copy a portfolio plan?
