How do you create notifications based on issue severity?
BernardH
I want notifications to go out to a group based on Critical & Major only.
I have tried a notification scheme (it does not allow you to specify severity)
I have tried subscription, but I don't want to spam the users showing ALL notifications based on my filter. I want the notification to pop when the critical/major issue is created.
Thoughts?
Vladimir Horev _RaleyApps_
November 9, 2015 edited
You can try our plugin Raley Emails Notifications - https://marketplace.atlassian.com/plugins/net.vacom.jirassimo
Define your custom JQL as "severity in (Critical, major)" and specify email destination.
Udo Brand
December 10, 2014
Subscription is the only way I can think of. Since you want only a notification on creation, use a filter like:
created > -15m and severity in (Critical, major)
and use a group subscription (don't send mails if no results) with following cron expression
0 0/15 * * * ? *
BernardH
Thanks...testing this solution now! If this does not work I will try the plugin route offered by Paul.
Udo Brand
December 11, 2014
Pauls suggestion will not work if you're using JIRA Cloud, since this plugin (or others) aren't available. See: https://confluence.atlassian.com/pages/viewpage.action?pageId=315326753
Paul Fink
Install the "Jira Scripting Suite" plugin (free)
You can then add a post function to workflow (on the Create Issue transition) that will trigger a notification event based on the severity.
Udo Brand
December 10, 2014
But it is not available for JIRA Cloud...
Let's build A Rovo Agent 🤖
Save your spot
