Hi all,
Our team has been using Jira x Slack automation such that Jira tickets meeting certain conditions within release epics are gathered and their information is posted as Slack threads in corresponding Slack channels. While this is working fine, we have a big maintenance issue because we have to manually update each Jira automation's JQL for Lookup Issue action to refer to a correct parent epic.
For example, let's say parent epics for our next imminent releases are DEV-1111 and DEV-2222. The JQL for the corresponding Lookup Issue action for the Jira automation may be:
project = XXX AND issuetype = "Issue Report" AND "Parent" in (DEV-1111, DEV-2222)
Once either or both releases are rolled out, the JQL above is no longer valid and we would have to find the next releases to be monitored (e.g. DEV-3333 and DEV-4444). Then we end up manually finding the corresponding epic links (DEV-3333 and DEV-4444) and putting them in the JQL.
So I thought of adjusting the automation in a way that it does not look at a specific epic link. Instead, it would consider status of an epic link:
project = XXX AND issuetype = "Issue Report" AND find_parent_epic_status = in_progress
However, it seems like the italicized / underlined JQL condition written in a pseudo way just does not exist.
How can I implement a Jira automation using Lookup Issue action w. JQL in a way that I do not have to manually update epic links? I feel like there may be a default Jira feature that can fulfil the needs, but I'm looking past it perhaps.
Thank you in advance
One simple way would be to use labels in your search term:
e.g. project = XXX AND issuetype = "Issue Report" AND labels in (Next_Release)
You would only then have to update the label for each ticket
You could then use automation to add/remove labels so you only have to add the 'Next_Release' label to an epic and the automations will add the label to child issues and remove it when the epic is done:
Alternatively use fixversion:
e.g. project = XXX AND issuetype = "Issue Report" AND fixversion in unreleasedVersions()
All you need to do then is create and manage releases
Hi @Bryan Kim
For a question like this, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected. Those will provide context for the community to offer ideas. Thanks!
Until we see those...
You could perform two lookup issues actions:
project = XXX
AND issuetype = "Epic"
AND status = "In Progress"
project = XXX
AND "Parent" IN ( {{#lookupIssues}}{{key}}{{^last}}, {{/}}{{/}} )
Next time I will share images of automation rules! And I did not think about using two lookup issues consecutively. Will give it a shot, thank you
Hi @Bryan Kim
You can look at the option provided by @Stephen.Lugton
If this is not what you are looking for is the option to extend your JQL functions. This will require a marketplace to fulfil this option.
This can't be done ootb.
Jira apps that can extend JQL and have hierarchy related JQL options for multiple issues are:
It is unfortunate that it cannot be done out of the box :/ I will look at Stephen's suggestion, and explore Jira apps if it doesn't work out. Thank you Marc!
