Sign up Log in
How do you make a Jira project visible to anyone without logging in?
David Yeager April 30, 2018
I want all issues visible to the world without having to log in. Is there a setting for this? Thx.
Ryan Kearney
April 30, 2018
Thanks for your response. I just checked under Project Name->settings->permissions->'browse projects'->'grant permissions' and the only available options for "granted to" are:
Project Role
Application access
Group
Service Desk Customer - Portal Access
Reporter
Current assignee
Single user
Project lead
Group
custom field value
Any other suggestions?
Like Jolly Singh likes this
Nic Brough -Adaptavist-
April 30, 2018
You've missed the line in the doc that says "group".  "Anyone" is an option in the list of groups.
Like Kevin Bianchi likes this
Beauty! Yes once I select "Group" there is an option "Anyone". Thanks for the help guys!
Ryan Kearney
April 30, 2018
No problem! You can mark a question as answered by hitting the checkmark to the left of the submitted answer. This helps other users in the future who might have a similar question.
Roman Kovalevsky April 28, 2021
hi there,
I just did add the anyone group, but still it asks to login when I open the backlog page https://kovalevsky.atlassian.net/secure/RapidBoard.jspa?rapidView=4&projectKey=FILL&view=planning.nodetail&selectedIssue=FILL-7&versions=visible&issueLimit=100.
Is there any specific link I should share for such anonymous access?
April 29, 2021
You can't enable anonymous access to boards - boards can only be used by software users (which means they have to log in so that Jira can tell that they're allowed to use it)
Roman Kovalevsky May 1, 2021
hm, isn't this parent question literally ask the same? seems like there was an accepted answer, which made me think that it is possible
May 1, 2021
Projects and boards are different things.  The accepted answer is about projects, as the question was about project access.
Roman Kovalevsky May 2, 2021
so you are saying there's no way to give access to the board to everyone on the web?
May 2, 2021
Correct, boards are a function of Software, and you need to be a licenced user to use boards.
Register Now
Upcoming Jira Events
