×Recently, a new part of the jira issue page is showing up, and pushes useful content off the screen. Tempo is not used, it wasn't asked for, it just showed up, much like all the other added fields to the jira page to make it less usable. What does it take to make this part of the page go away?
Please refer tempo documentation Hide the Tempo panel on the Jira issue view with ScriptRunner to hide it with ScriptRunner.
Hi @Fred Rush
The Tempo panel is only available in the JIRA issue view when the plugin is installed on your instance.
In case you are not using the plugin, it is recommended to uninstall it as on installation, the Time tracking provider is set to Tempo, instead of the native JIRA time tracking ( JIRA Settings, Issues, Time tracking).
Users who do not have access to the Tempo plugin will also not be able to view this panel in the issue view. Access to Tempo is given via the JIRA Global permissions, see also https://tempo-io.atlassian.net/wiki/spaces/THC/pages/362971589/Managing+Access+to+Tempo+Timesheets+for+Cloud+and+Tempo+Planner+for+Cloud.
Best regards,
Susanne Götz
Tempo team
The issue appears to be that another project in the instance wants to use Tempo, so the plugin is installed. But there is no way to make it go away on a project level, so 99% of the projects not using it, must now suffer with it for the 1 project using it. This is simply poor design.
This bug seems to reapear.
Of sudden in the Backlog screen when we choose one of the tasks the Tempo panel appears, and if we click to Hide, it does not work, I first must click to add the Tempo plan track time, after that the hide button works.
The weird thing for us is that this is intermittent. Sometimes it appears, some times it doesn't. My colleague and I were looking at the same issue and he could see this and I didn't.
This is also happening for two other plugins we use.
This is how you do it in cloud: https://tempo-io.atlassian.net/wiki/spaces/THC/pages/172326913/Tempo+in+the+Jira+Issue+View+-+Tempo+Cloud
Apparently not, no ... in the tempo area to click on to make it go away.
This is the entire area of the page that needs to go away
There is also no tempo button at the top of the page. Appear to be stuck with another rotten update from atlassian.
I agree, I would like to remove this from the issue view. Could you make it so that we can disable it in the settings, just like e.g. BigGantt, see https://community.atlassian.com/t5/Jira-questions/Remove-BigPicture-and-BigGantt-charts-from-certain-projects/qaq-p/667635
Unsurprisingly, no. There is no response to bugs like this reported, nor is there any attention paid to usability. Whatever they want to force on customers is what you'll take and like it.
Any updates on this? - most plugins have the ability to choose the project which it is enabled for.
There seems to be a lot of us struggling here with Tempo removal. It's a huge eye sore, and most of the time unnecessary in our projects. As stated above, other projects have to suffer because of 1.
Do we have an update here?
We ended up removing it using scriptrunner - then you can choose pr. project
Jesper, how exactly did you remove it via scriptrunner? I see the guide to do it through fragments but the options the guide references are not available.
