How do you set up federation for JIRA?
Aram Ghanimian May 12, 2016
I am going to have multiple production instances for JIRA Software. I did some reading on federation and at the end of the article, there was a recommendation to connect with an Expert. Is it really as hard as it sounds?  Do you need to be on a specific version of JIRA for this to work? I just need to get started in the right direction.
Cheers!
Deleted user May 12, 2016
Are you talking about JIRA Data Center? It's not that hard, Atlassian have very good documentation about it.
https://confluence.atlassian.com/jira/installing-jira-data-center-604274940.html
That KB links is very straight forward. Setting up JIRA with different availability and redundancy will depend on how your team set it up and what you implement along with it. It should not be that hard.
Nic Brough -Adaptavist-
May 12, 2016
That article could do with some updates - there's a new add-on that can help with synchronisations, the info about Script Runner is out of date (it's supported now, and yes, I work for Adaptavist) and so-on.  The basic ideas are still right of course.
