How does one set the default permissions scheme that is used for new projects?
Priyanka Khare
In jira, application ships with a "Default Permissions Scheme" already prepared, and it is described as the scheme that is automatically assigned to any new project.
If you remove all projects from this scheme, you are able to delete the scheme. Creating a new scheme afterwards, doesn't give any indication whether its the default. So, now, if you have multiple schemes, and you've deleted the 'default,' it is no longer apparent which scheme is now the default, nor is it apparent how to set the default.
Kian Stack Mumo Systems
You shouldn't be able to delete the Default permission scheme. Atlassian doesn't have a way to set the default, so I don't know how your instance will behave.
Read the story
