How is bug tracking/ defect tracking presently being execute since the ‘Issue Type’
koteswararao
March 20, 2019
  • How is bug tracking/ defect tracking presently being execute since the ‘Issue Type’ ‘Bug’ is not enabled it seems
Nic Brough -Adaptavist-
March 20, 2019
You will need to explain this better - you've given us a fragment of a problem without any context.
What do you specifically mean by bug/defect tracking?  This means different things to different people.
If you need an issue type of "bug", either select a project type that has it by default when you create it, or add the type - I'm not sure what you are missing there?
