I've a KCF Single Autocomplet customfield whith this Select script:
KPOption[] kpOpt = #{Seleccionar técnico soporte};
string seleccion = kpOpt[0].value;
customfield_11904=seleccion;
assignee="admin";
The customfield_11904 has the rigth value but the field assignee remains empty. What am I doing wrong?
I have resolved same issue using those two lines:
KPOption [] assigned = customfield_10501; //This is KCF Pro single autocomplete field
assignee = assigned[0].value;
Hi Begoña,
Try this: assignee=getUser("admin");
Is the script above the select script or the datasource? If it is the select script, how does the datasource looks like? Is customfield_11904 your KCF Pro? You want to set the assignee to an user which has admin as username? Please be more specific. Thank you, Alexandra
My KCF Pro is customfield_20901. It's datasource script is: string grupo_soporte = argv["customfield_20900"]; //Seleccionar grupo soporte string query = "SELECT "; query += " display_name||' ['||user_name||']' nombre"; query += " from cwd_user u"; query += " LEFT JOIN cwd_membership g ON u.ID = g.child_id"; query += " WHERE parent_name='"+grupo_soporte+"'"; query += " order by u.user_name"; string[] resultado = sql("JiraDB",query); return resultado; The customfield_11904 is a customfield that I've to fill depending on the value of the KCF. Thus, the select script of my KCF (customfield_20901) is: KPOption[] kpOpt = customfield_20901; string seleccion = kpOpt[0].value; customfield_11904=seleccion; assignee=getUser("admin"); I'm testing with this simple values (seleccion and "admin")
I have just tried what I suggested you and it works. Could you please set the LOG level to debug and check if there's anything relevant? :)
Actually, it also works with assignee = "admin". Waiting for the LOG. :)
In the log I can see: In the log I can found: 2015-12-21 15:03:59,998 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Field customfield_20901 was not modified. Current value: [KPOption[]] {[Inmaculada Sanchez [sanchez_inm], Inmaculada Sanchez [sanchez_inm]]}. Issue value : [KPOption[]] {[Inmaculada Sanchez [sanchez_inm], Inmaculada Sanchez [sanchez_inm]]} 2015-12-21 15:03:59,998 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Retrieving field assignee from issue AXIS-39262 2015-12-21 15:03:59,998 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Value of assignee on issue AXIS-39262 is [STRING] 2015-12-21 15:03:59,998 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Saving to issue AXIS-39262 field assignee with value [STRING] admin|admin|admin|dgti@excentia.es 2015-12-21 15:03:59,999 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Retrieving field key from issue AXIS-39262 2015-12-21 15:03:59,999 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Value of key on issue AXIS-39262 is [STRING] AXIS-39262 2015-12-21 15:03:59,999 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Field key was not modified. Current value: [STRING] AXIS-39262. Issue value : [STRING] AXIS-39262 2015-12-21 15:04:00,000 atlassian-scheduler-quartz1.clustered_QuartzSchedulerThread DEBUG [quartz.impl.jdbcjobstore.SimpleSemaphore] Lock 'TRIGGER_ACCESS' is desired by: atlassian-scheduler-quartz1.clustered_QuartzSchedulerThread 2015-12-21 15:04:00,000 atlassian-scheduler-quartz1.clustered_QuartzSchedulerThread DEBUG [quartz.impl.jdbcjobstore.SimpleSemaphore] Lock 'TRIGGER_ACCESS' is being obtained: atlassian-scheduler-quartz1.clustered_QuartzSchedulerThread 2015-12-21 15:04:00,000 atlassian-scheduler-quartz1.clustered_QuartzSchedulerThread DEBUG [quartz.impl.jdbcjobstore.SimpleSemaphore] Lock 'TRIGGER_ACCESS' given to: atlassian-scheduler-quartz1.clustered_QuartzSchedulerThread 2015-12-21 15:04:00,007 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [plugins.databasecf.config.ConfigurationCache] Loaded configuration >>databasecf.View Type_11904<< (1) 2015-12-21 15:04:00,017 http-bio-8080-exec-3 DEBUG bonet_beg 903x21201x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [commons.jira.utils.IssueUtils] Updated issue >>AXIS-39262<< The most relevant thing for me is: 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Saving to issue AXIS-39262 field assignee with value [STRING] admin|admin|admin|dgti@excentia.es I think I need to get only the username. Doesn't it?
Using: assignee="admin"; I can see in the log: 2015-12-21 15:11:26,785 http-bio-8080-exec-21 DEBUG bonet_beg 911x21502x1 i1xbn2 10.178.169.107,10.178.169.107,172.27.146.22 /secure/CommentAssignIssue.jspa [jira.commons.ivm.SILIssue] Saving to issue AXIS-39262 field assignee with value [STRING] admin The problem is that my issue remains without value for "assignee" :-(
It all looks all right to me, I don't get why the value isn't set. It's ok to use the username, yes.
The new value doesn't appear neither after you refresh the page?
no, and if I launch a JQL like "project=AXIS and assignee=admin" no issue is found.....very strange
Hmm... indeed, I don't get why the assignee isn't set.
Register today!Online forums and learning are now in one easy-to-use experience.
