Hi @Akshay Bhor and welcome to the community,
If you are on a free plan as you state, you have the same priviledges as anyone else. You should be able to view the project. If you are not, then you have to speak to your admin which is usually contacted via this link: https://YOURDOMAIN.atlassian.net/jira/contact-administrator (replace the YOURDOMAIN with your actual domain)
Let me know if that helped.
Hi @Akshay Bhor
Reach out the the admin of this site to get permissions on the site or the project.
Only admins of an instance can grant you access to a cloud instance. Community member or Atlassian can't grant you permissions.
Hi @Akshay Bhor
No I can't.
Is this Atlassian instance an instance you have access to? If I click the link it seems the project has been archived or deleted as I don't get the message that I can't access this instance and need to request permission
Hi @Akshay Bhor
Please mark my answer as the solution, as this will help other community members with the same type of question.
