How to Change email domain in jira
Yogesh Mude[Jira]
November 2, 2016
we want to changes all JIRA User email  domain with new domain.
example : previous mail address  user@abc.com
                new mail address user@xyz.com
All JIRA Users are configured through the LDAP..
Yogesh Mude[Jira]
November 3, 2016
Hi
We were not configured any LDAP server, crowd or other JIRA server with JIRA .
All users configured through JIRA  Internal directory only.
we are done this through the database, below  are the SQL queries
1.SELECT id FROM cwd_directory WHERE impl_class = 'com.atlassian.crowd.directory.InternalDirectory';
2.UPDATE cwd_user SET email_address = replace(email_address,'<PreviousDomain>','<NewDomain>') WHERE directory_id = <ID from step 2>;
3.  UPDATE cwd_user SET lower_email_address = replace(lower_email_address,'<PreviousDomain>','<NewDomain>') WHERE directory_id = <ID from step 2>;
Jonas Andersson
November 2, 2016
I assume you run JIRA on Linux.
  • Shut down jira.
  • Dump database to a file named your.database.dump.sql
  • do this:
cat your.database.dump.sql | sed 's/@abc\.com/@xyz\.com/g' &gt; new.database.dump.sql
  • import the database again
  • start up Jira, reindex it.
Before doing this on production, make sure you have done it on a test instance and tested everything (like that you have equally many issues assigned, and so forth.
I have merged 4 AD domains into 1 AD domain once using this technique, so know it works, but testing it will make sure you don't run into anything i did not.
Good luck!
Yogesh Mude[Jira]
November 2, 2016
Hi @Jonas Andersson
First of all thanks for ur response.smile
Might be this answer is correct as u assumes JIRA is running on Linux.
but our JIRA is running on Windows, for this what changes we need to do??
Learn more
