×Hello @Sam Lin
1. What are the triggers for the rules? If you have specified triggers other than Manual or Incoming Webhook, the the rules will execute when the action in the trigger occurs and you cannot specify the order in which they execute.
Can you provide more details about your scenario? Provide an actual example of a sequence of rules in the order you would want them to execute. Tell us the trigger of each rule and describe what the rule does.
2. In the Audit Log for each rule there will be entries with the status "Config Change". Those entries will contain all the information that Atlassian makes available about changes to the rule. It will not contain all the details that you want
