×Hi,
Is there a way we can export Burndown chart or Sprint details into Excel..
-Bala
Community moderators have prevented the ability to post new answers.
Hi Bala,
Actually is not possible directly in GH, the only I can think about is to filter the issue navigator base on the 'Sprint' and then export it through the issue navigator (Views -> Excel (All fields)).
To learn how to filter the sprints, you can refer to this link: https://confluence.atlassian.com/display/ONDEMANDKB/How+to+Get+the+Sprint+Filter+Link+in+the+Rapid+Board
Hope it helps!
Omar
No worries Bala :).
The link in Omar's reply does not exist anymore.
It's 5 years old, things have changed.
Hi Bala,
As far as I know, this is not possible for the time being. However, you might like to try going to the Sprint Report, then clicking 'View in Issue Navigator'. You can then export the list to Excel.
Joe
okay thanks Joe. It would be very useful if we have this feature. it will save lot of time. Not sure if some one already raised this feature request in Jira.
