Hi there,
I am actually following up four projects on Jira. And, when exporting the tickets, it is a bit messy:
It is requesting a prior check each time before analysis and it is really time consumming so, I hope someone can have an idea of how to fix it.
for point 1, when you say some tickets are not under the right project....is the excel data matching the data you see in Jira interface?
also you mentioned some ticket are not even linked to a project, technically this is not possible because any ticket must be created under project so it would be great if you can elaborate a bit more please
point2, to help you on this i would need to see some screenshots at least from the excel for the parent task that has subtasks linked to it in excel and another screenshot for the parent ticket from Jira
generally speaking, if you are after extracting excel file then the key would be to work on your JQL query to get exact tickets you are after either to have it project based or using any other field that will limit your results and that should help to have less data to work with in excel and less confusion.
