How to add a Scope for Specific Project
Vitheya Monikha May 9, 2025
Hi ,
I’ve created custom field which is a dropdown.  So, for that I am adding the options dynamically using the below APIs
API URL'S
1. /rest/api/3/field/${fieldId}/context
2. /rest/api/3/field/${fieldId}/context/${globalContext.id}/option
The options are added successfully, but it is not project specific. The options are visible under all the projects under my account. So i need a way to apply project scope for each option I create.
Any guidance or insights from the community on how to proceed functionality it would be greatly appreciated.
I’ve attached the relevant code snippet below.
resolver.define("addOptionToCustomField", async({payload}) => {
  const { fieldId, name } = payload
  try{
    const contextResponse = await api.asApp().requestJira(route`/rest/api/3/field/${fieldId}/context`, {
      method: "GET",
      headers: { "Accept": "application/json" },
    const contextData = await contextResponse.json();
    const globalContext = contextData.values.find(ctx => ctx.isGlobalContext);
    const optionData = [{ value: name }];
    var res = await api.asApp().requestJira(route`/rest/api/3/field/${fieldId}/context/${globalContext.id}/option`, {
        method: "POST",
        headers: {
            "Accept": "application/json",
            "Content-Type": "application/json",
        body: JSON.stringify({options: optionData}),
      const data = await res.json()
      return data
  catch(error){
    return {"code": 2000, "message": "Error while creating folder"}
Thanks in advance for your help!
Jaime Escribano (knowmad mood)
Good Morning Vitheya!
I can see in this code snipet
that you chose the global context of the field, which is the reason why it shows up in all projects.
You would need to define a new context for each set of projects you want your field to have different options in.
const targetContext = contextData.values.find(ctx => ctx.name === "specific Context");
You can read more about contexts here:
https://support.atlassian.com/jira-cloud-administration/docs/configure-custom-field-context/
Hope that was helpful. Let me know if you need more help!
Jaime Escribano
Vitheya Monikha May 12, 2025
Hi Jaime,
As you Suggested I've set Specific context but still its fail, I've attached the code snippet below kindly take a look.
Code Snippet
  const { fieldId, name, projectKey } = payload
  try{
      method: "GET",
  const targetContext  = contextData.values.find(ctx => ctx.name === projectKey);
    var res = await
/rest/api/3/field/${fieldId}/context/${targetContext}/option`, {
        method: "POST",
        headers: {
      return data
  catch(error){
Good morning Vitheya! Hope you enjoyed your weekend.
Before I look into this, would you share what the failure is? API Error, result is not the same as expected, some other issue?
Jaime
Hi Jaime,
This is error I'm getting
"Error while creating folderTypeError: Cannot read properties of undefined (reading '0')"
I've  also attached UI code for your reference kindly take a look
Code snippet 1:
 const onSubmit = async (data) => {
      var bodyData;
      setIsLoading(true)
      const folderExists = tree.some(folder => folder.value === data.folderName || folder.value === `${data.folderName}(${parentFolderName})`);
      if (folderExists) {
         setIsLoading(false)
         setFlagTitle('Failure!');
         setFlagMessage('Error: Folder name already exists');
         addFlag();
         return;
      if (parentFolderName === 'Test Repository') {
         bodyData = {
            fieldId: testCaseFieldId,
            projectKey: projectKey,
            projectId: projectId
      else {
         console.log("else..........", projectId)
         bodyData = {
      try {
         const response = await invoke('addOptionToCustomField', bodyData); // API call to get projects
         if (response.options[0].id) {
            setIsLoading(false)
            setFlagTitle("Success!")
            setFlagMessage('Folder created successfully')
            setIsOpen(false)
            setShowParentDrp(false);
            reset();
            addFlag();
            setTree([])
            setFolderLoader(true)
            getUpdatedComponentList()
      } catch (error) {
         setIsLoading(false)
         setFlagMessage(`Error while creating folder${error}`)
         addFlag();
         return [];
Code snippet 2:
  try{
    console.log("Payload to create options...", fieldId)
      method: "GET",
    var res = await api.asApp().requestJira(route`/rest/api/3/field/${fieldId}/context/${targetContext}/option`, {
        method: "POST",
        headers: {
      return data
  catch(error){
Vitheya Monikha May 15, 2025
Hi ,
How can I set scope for a specific project? In case you haven't seen the code snippets, I've sent them again. Please take a look at them
UI Code
      var bodyData;
      setIsLoading(true)
      if (folderExists) {
         setIsLoading(false)
         addFlag();
         return;
      console.log("ParentfoldernameID..........", projectId)
         bodyData = {
         console.log("bodyDataID..........", projectId)
      else {
         bodyData = {
         console.log("projectid..........", projectId)
      console.log("Data...", bodyData)
      try {
         console.log("comp Response....", response)
            setIsLoading(false)
            setIsOpen(false)
            reset();
            addFlag();
            setTree([])
      } catch (error) {
         setIsLoading(false)
         addFlag();
         return [];
Backend Code
  console.log("addOptionToCustomField")
  console.log("projectkey.........",projectKey)
  try{
      method: "GET",
    console.log("contextData......", contextData)
    console.log("Option Data........", optionData)
        method: "POST",
        headers: {
      console.log(`✅ Dropdown options added for ${fieldId}!...`, data);
      return data
  catch(error){
