How to add a condition about subtasks created in automation rules
Raquel Muñoz Gutiérrez January 16, 2025 edited
Hi!
I want to create subtasts automatically but only once.  I created a rule to create several subtastks with the "manual" trigger.
The problem is that I wanted to add a condition so the subtasks only can be created the first time you action the rule, so the subtasks aren't duplicated,  but I don't get how to configure that condition.
Any idea?
2 accepted
5 votes
Atlass Monster
Banned
January 16, 2025
@Raquel Muñoz Gutiérrez  Hi hi to you.
This should work
Thank you!!! I was searching something like this but I wasn't using the functions properly.
JM Perrot
Hello @Raquel Muñoz Gutiérrez and welcom among us!
I think you can add a hidden (or visible, your choice) numeric custom field and incorporate two steps into your automation.
  1. At the end of your automation, set this field to "1" to indicate that the automation has already been executed.
  2. After the trigger, check the value of this field. If it is already set to "1," the rule will not execute further.
This approach should help prevent duplicate executions of the rule. Let me know if you need further clarification!
Step-by-Step Guide:
  1. Create a Numeric Custom Field:
    • Go to Settings > Issues > Custom fields.
    • Create a new Numeric custom field, e.g., "Subtask Created Flag"
    • Associate it with the appropriate screens.
  2. Modify Your Automation Rule:
    • Trigger: Set the trigger as "Manual" (you already have this).
    • Condition: Add a Condition step right after the trigger:
      • Select Advanced Compare Condition Or issue field Condition.
      • if you choose Advanced Compare Condition, set it to:
        {{issue.Subtask Created Flag}} != 1
        This condition ensures the rule won't proceed if the flag is already set to 1.
    • Actions:
      1. Add the actions to create subtasks as usual.
      2. Add an action at the end of the rule to Edit Issue:
        • Set the "Subtask Created Flag" field to 1.
Optional Tweaks:
  • Make the Field Hidden: If you don't want users to see this field, you can:
    • Remove it from all screens.
    • Use Jira's API to check or reset the value if needed.
  • Reset the Field: If you ever need to allow the subtasks to be recreated, you can manually or automatically reset the custom field to 0.
Wow! Thank you so much! It's a simple and easy solution, I can't believe I didn't get to it myself.
JM Perrot
You're very welcome, Raquel! Sometimes the simplest solutions are the hardest to spot when you're deep in the problem.
Don't hesitate to reach out if you have more questions or need help fine-tuning your automation.
