How to add a custom JQL function to search for history of the custom field.
nallu February 14, 2019 edited
I have a requirement to develop a custom JQL function that will search for history of custom fields.
Ex: custom_field_X was 18.11
This should list out the issues which had value as 18.11 for  custom_field_X.
Can anyone please tell me where should i start and suggest me the right tutorial/document?
Moses Thomas
@nallu  Why not use the built in  issueHistory() function  which  displays  recently viewed  issues so   this  function issueHistory() returns up to 50 issues.
so  you  can  write  a filter like this
issuekey in issueHistory() AND  custom_field_X = "2 - Critical"
at-least  you  can get  up  50 issues.  instead of developing your  own plugin.
but  if  you  insist  then check  this out  this could be  helpful
https://developer.atlassian.com/server/jira/platform/adding-a-jql-function-to-jira/
best regards,
Moses
