How to add a select cascade field value in a custom email [script runner postfunction]
Fabio Manzoni
Hi Guys,
I'm following the documentation to send Send a custom email using a custom field https://scriptrunner.adaptavist.com/4.3.6/jira/builtin-scripts.html. It works, but with some problems.
The code
Custom field : <% out <<
issue.getCustomFieldValue(com.atlassian.jira.component.ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("my select cascade field")) %> <
I'm using a select cascade field and the preview shows this.
Custom field : [null:JIRA SOFTWARE, 1:jira-users - Jira Users]
Why apperas the nulll and number 1?
Can I remove this values?
3 votes
Alexander Pappert
December 30, 2020
see https://community.atlassian.com/t5/Jira-questions/How-to-add-a-multi-select-dropdown-custom-field-value-to-custom/qaq-p/854441
Custom field value: <% out << issue.getCustomFieldValue(com.atlassian.jira.component.ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("MySelect"))*.getValue().join(', ') %>
For a multiselect list getCustomFieldValue() returns a collection of Option object. With *.getValue() you convert this collection to a collection of the values of these Option objects. The value is the text the user sees. With join(', ') you convert this collection to one string, if there are multiple values these are separated by a comma.
Fabio Manzoni
@Alexander Pappert ,
Your script worked, thank so much for your help.
Like • 2 people like this
Help us plant more trees
