How to add a shared filter to the quick filter of my Kanban board?
Julia_Pflibsen April 2, 2020
I have a shared filter that has "open" permissions. I would like for that filter to be available on the  Kanban board without me have to retype the query. How do I do that?
Julia
Angélica Luz
April 6, 2020
Hello Julia,
When adding a Quick filter to a board, currently, it's necessary to add the JQL, it's not possible to search by saved filters.
It will be necessary to go to the filter, switch to Advanced/JQL in order to copy the JQL and paste it into the quick filter search box.
Angélica
Julia_Pflibsen April 6, 2020
Thank you for your explanation. Is there anyway to build a jql query in that window or do I have to go to the filters view, build it using the basic/advanced view and then copy and paste it into the board filter?
thanks!
Julia
Angélica Luz
April 7, 2020
Yes, you can create the JQL directly from the Quick Filters menu. What I mentioned in the previous comment is that, if you already have a filter, you can open this filter, switch to the advanced mode in order to copy, so you won't need to type the JQL again (if it's a complex one).
Julia_Pflibsen April 7, 2020
thanks!
Like Angélica Luz likes this
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
