Hi Andy,
I think this should be possible, by configuring the filter for the created board. You can try to do this by opening the board, open the Tools drop down, and select Configure. You will see the board configuration, open the Filter tab and chance the filter query to include other projects:
sample JQL: project = "TST" OR project in (TES, TEST)
We can modify the filter query by opening the Saved Filter (View in Issue Navigator), and make changes to the JQL query and save the filter.
Hope this helps!
Cheers
Thanks. The confusing part was being able to get to an "edit filter" page via the board config. But on that page there's no way to edit the filter's JQL query -- I had to get to "edit filter" from the issue navigator before I could edit the JQL.
Learn more
