Hi, just like the screen shot, I want to show assignee detail in linked issues list, like sub-task. Is that possible? May I know how to do this? Thank you.
Hi, @Jason Liu
Issue Links block cannot be modified by default. It's built-in functionality of Jira, and customization is unavailable.
Hi @Jason Liu
as others have suggested, this isn't currently possible, however if you're open to solutions from the Atlassian Marketplace, you should get pretty close; see e.g. this thread for possible directions forward.
Since you've tagged your question for Jira Server: As you may have heard, app sales have ended for Jira Server. Are you planning to migrate to Data Center or Cloud? I'd strongly recommend that; you'll have way more options there.
Best, Hannes
What others are saying - https://jira.atlassian.com/browse/JRASERVER-36490
However, if you look here - https://community.atlassian.com/t5/Jira-questions/How-do-you-add-a-column-to-quot-Issues-in-Epic-quot-panel/qaq-p/292561 - if you were crafty enough you could modify the table through javascript to include an extra column. There are some examples how this works and issue links is relatively similar-ish in nature, just checking the DOM you could parse the issue key out of, get the assignee through REST, and include it. Although it might be a bit tricky with issue link pagination.
Hi Jason,
Unfortunately, no, that is not possible. You should open a support request with Atlassian to ask them to add that feature.
