Hi Team,
How to add colors to radio button option. I tried <p style="color:#008000">GREEN</p> however it is displaying all the HTML content as a option.
Thank you,
Suchit
In 'General configuration' there is a setting called "Enable HTML in field descriptions and list item values" which has to be enabled first.
Although of course it goes without saying it's a "security concern" so you might want to think about enabling it globally.
Not sure about the p tag, probably would try span instead (I think p might throw formatting off), but I know this can be done I've created similar lists before, so it comes down to enabling javascript first in global settings.
Hi Radek,
Enabling the "Enable HTML in field descriptions and list item values" in general configuration works.
Thank you so much!
Thank you,
Suchit
