Hello Everyone,
I want to validate, whether it is possible to add field on transition screen, i.e. when workflow state is "closed" from workflow named as "workflow A" and project named as "Demo Proj". Is this possible to implement it using script runner and also this custom field , which needs to be added is mandatory ,when workflow state is "closed".
Kindly guide me by sharing some references or some example ,if it is possible.
Thanks and Regards,
Jyoti
Hi @Jyoti Kumari ,
This is possible withouth SR. Have a look at:
https://confluence.atlassian.com/jirakb/add-a-custom-field-to-transition-screen-718834736.html
/Markus
Thanks Markus,
I want it through automation(jira script runner or jira plugin),as if we apply it through GUI then it will be apply to all projects ,which is using that workflow.Is it possible to do it through script runner.
