Hello
I am trying to figure out how to add fields that appear under main task, to also appear under sub-tasks automatically.
Hi @Angus Smith
You would need to have the field on the screen(s) used by the work item sub-task and make use of automation to copy these fields when a sub-task is created from the parent.
Hi Marc
Thank you for your answer. Here is an example of the main task with a view of the first 3 subtasks. I am trying to understand exactly what you mean. (I think in pictures)
Hi @Angus Smith
Please accept my answer as a solution, if my answer helped to solve your request.
This will help other community member trying to solve the same.
P.S. If the answer is very valuable to you, please share some kudos.
Hi, @Angus Smith! 👋
In order to sync the sub-task with the parent task, you can use automation (presuming you have the same fields on the sub-task screen(s)).
For example, if you want to copy the assignee field from the main task, you can use the following logic:
You can customize the trigger and fields as necessary.
Hope this helps! ✨
Screenshot of where sub-tasks are added to the main task
