How to add fields to comment in automation
roland_amann April 28, 2021
I am trying to add the value of a field to a comment when creating a new request. I just started fresh with a Service Management Project Template "HR Service Management". I am the only user right now and I have full administrative priviledges accordingly.
I created a new rule in automation which adds the comment to the issue without a problem.
Then I want in that comment the Value from the field "Start date". For that i used the help entry inside automation "How to access issue data in my comments".
I tried the following:
1 {{issue.fields.start date}} 2 {{issue.start date}} 3 {{issue.fields.start date.value}} 4 {{issue.start date.value}} 5 {{issue.fields."start date"}} 6 {{issue.customfield_10015}}
It is always empty. I tried the customfield because I found it when I read the field names by accessing https://<instancename>/rest/api/2/issue/<issuename>?expand=names
"Start date" is delivered with the HR Service Management Template. I did not create it myself. It's a default field. Why can't I access it? I also tried copying the field in the field due date. I can even select "Start date" from the drop down list to copy. But this doesnt't work either. Here I get the error message in the audit protocol:
More than one field with same name and type found: Start date (com.atlassian.jira.plugin.system.customfieldtypes:datepicker)
I don't understand what I am doing wrong and I couldn't find a proper documentation about how to access the fields and where I get the exact names I have to use.
Regards
Roland Amann
April 28, 2021
Hi @roland_amann
Smart value names are case-sensitive, so this one could be: {{issue.Start Date}}
When you want to learn the name of a specific smart value, you can try this method to compare the values in an issue which uses the fields:
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
Best regards,
Hi @[deleted]
Thank you. I looked in the names again. But this time I did not look for the name of the variable, but searched for the expected value. This worked.
The correct field name in my case is {{issue.customfield_10054}}. Why this is a custom field in the default form and why I can select it in a dropdown box and it still doesn't is beyond me.
But this is a solution I can live with. Thanks.
Regards
Roland
April 29, 2021
Roland, I am glad to hear that worked for you.
Between the UI/UX, REST API, and smart values, I often check the names with the technique I sent you when something doesn't seem to work as often it is a name mismatch.
Best regards,
Joshua Keele January 17, 2022
This does not work for me, can you share your exact syntax as it appears in your comment please?
roland_amann January 18, 2022
I put this in the field:
@Safety Roland Amann: Sicherheitsausrüstung benötigt ab {{issue.customfield_10054}}
Callum Carlile _Automation Consultants_
April 28, 2021 edited
Hi @roland_amann I have just tried this out with {{issue.start date}} and it worked fine for me.
Please may you provide a screenshot of your automation rule, just to double check its configuration
roland_amann April 28, 2021 edited
I made a manual trigger with action "add value to audit-protocol" (translated from german. I don't know if it's called exactly like that in english) and tried it. Did not work.
1 {{issue.fields.start date}} 2 {{issue.start date}} 3 {{issue.fields.start date.value}} 4 {{issue.start date.value}} 5 {{issue.fields."start date"}} 6 {{issue.customfield_10015}} 7 {{issue.startdate}}
Details zur Aktion:
Protocol 1 2 3 4 5 6 7
Zugehörige Elemente:
Manueller Trigger
HP-12
The comment is created in the task. But the date is empty.
Edit: Just to make sure. I want the value of the following field. This is the default jira hr Employee onboarding request type form:
FREE
