How to add issuelinks in rest api ?
Tech Habiteo August 22, 2019
Hi everyone,
I followed this article :
https://confluence.atlassian.com/jirakb/how-to-use-rest-api-to-add-issue-links-in-jira-issues-939932271.html
But it doesn't work.
Here is my request :
"fields":{
"project":{
"key":"XX"
"summary":"test bug summary",
"description":"test bug description",
"issuetype":
{"id":"XXXXX"}
"update":{
"issuelinks":[
"add":{
"type":{
"name":"Blocks",
"inward":"is blocked by",
"outward":"blocks"
"outwardIssue":{
"key":"XX-967"
Can you please help me ?
BBury March 2, 2021
using the post('/rest/api/3/issueLink') method works like gangbusters. the "update" method not so much.
Benoit
Is there anyone that manage to create a multiple inward issue?
Extract of automation:
"update":
{"issuelinks":[{
"add": {
"type": {"name": "Blocks"},
"inwardIssue": {"key": "{{#createdIssues.get(7)}}{{key}}{{/}}"},
"inwardIssue": {"key": "{{#createdIssues.get(6)}}{{key}}{{/}}"},
"inwardIssue": {"key": "{{#createdIssues.get(5)}}{{key}}{{/}}"}
Earl McCutcheon
August 23, 2019
Thanks for reaching out and fist it looks like you are Looking at the Jira Server Docs for the API formatting but your account is tied to a Jira Cloud address, The Formatting you are using for the data portion is for Jira Server and should be working without issue on a POST api/2/issue
If you are on Jira Server and this is failing what is the full syntax of the call you're using, and what is the Response error message you are getting when the call is failing?
For Jira Cloud:
The Documentation for the API can be found here:
There are a few changes needed for the call on the cloud side, You will want to use the version 3 endpoint for issue and do a POST /rest/api/3/issue
Then there is some additional formatting requirement on the Description where you currently have is set as "description":"test bug description", it should be formatted as follows:
    "description": {
      "type": "doc",
      "version": 1,
      "content": [
          "type": "paragraph",
          "content": [
              "text": "test bug description",
              "type": "text"
So the Full data portion should look like this:
   "fields":{
      "project":{
         "key":"XX"
      "description": {
          "type": "doc",
          "version": 1,
          "content": [
              "content": [
                  "type": "text",
      "issuetype":{
         "name":"Bug"
      "priority":{
         "name":"Major"
   "update":{
      "issuelinks":[
            "add":{
               "type":{
                  "name":"Blocks",
                  "outward":"blocks"
               "outwardIssue":{
                  "key":"XX-967"
Earl
Tech Habiteo September 24, 2019
Hi Earl, thank you for your answer. You're right, I'm on Jira Cloud sorry. I tried with your answer but I still have the same problem on api/3 or api/2
"fields":{
"project":{
"key":"RD"
"description": {
"type": "doc",
"version": 1,
"content": [
"content": [
"type": "text",
"issuetype":
{"id":"XXXX"}
"update":{
"issuelinks":[
"add":{
"type":{
"name":"Blocks",
"outward":"blocks"
"outwardIssue":{
"key":"XX-967"
Curl :
curl -X POST \
https://XXXXX.atlassian.net/rest/api/2/issue \
-H 'Authorization: Basic XXXXXXXXXXXXX' \
-H 'Content-Type: application/json' \
-H 'cache-control: no-cache' \
-d '{
"fields":{
"project":{
"key":"XX"
"description": {
"type": "doc",
"version": 1,
"content": [
"content": [
"type": "text",
"issuetype":
{"id":"XXXX"}
"update":{
"issuelinks":[
"add":{
"type":{
"name":"Blocks",
"outward":"blocks"
"outwardIssue":{
"key":"XX-967"
And the API send me this error :
"errorMessages": [],
"errors": {
"issuelinks": "Field 'issuelinks' cannot be set. It is not on the appropriate screen, or unknown."
Earl McCutcheon
September 24, 2019
Hey there,
The formatting looks good but the error you are encountering is related to the field:
The noted field "issuelinks" is going to be the "Linked Issues" field on the system front end,  And it is either missing from the Create screen of the inward links project or the Edit Screen of the outward links project.
Earl
Tridib Choudhury
September 1, 2020
Hi, I have exactly same scenario. But my case the field is already there in on the screen.
Still getting below error :
"Field with id' issuelinks' and name 'Linked Issues' does not support operation 'outwardIssue' Supported operation(s) are: 'add'"
Puján Z
it seems this update part simply doesn't work in the create part of the Cloud API. And if you submit a bug report it will rest in "gathering impact" peace for half a decade. So after a few hours and a dozen new gray hairs, here is how I solved it (first create issue, and then update/add a link):
def resultingCreatedIssue = post('/rest/api/2/issue')
.header('Content-Type', 'application/json')
.queryString("overrideScreenSecurity", Boolean.TRUE)
.body(
fields:
project: [
issuetype: [
summary : samplingRequestSummary,
description: samplingRequestDescription,
(whateverIssueCFID): whateverValue
.asString().body
JsonSlurper slurper = new JsonSlurper()
def pasedJson = slurper.parseText(resultingCreatedIssue)
assert pasedJson instanceof Map
String createdIssueKey = pasedJson.key
//.queryString("overrideScreenSecurity", Boolean.TRUE)
.body([
type:[ name: "Name of My Link" ],
inwardIssue: [key:targetKey],
outwardIssue: [key: createdIssueKey]
.asString().body
Hope it saves you guys a few hours ;)
Like • BBury likes this
BBury March 2, 2021
@Puján Z , thank you. @Atlassian take note.
Register now
